Community Member
vrf routing on a 3750
Hi, here is my situation. I am setting up a test lab with 2 mpls routers, but only 1 3750 switch. I have the vlans configured and subnets setup.
vlans are as follows:
vlan 120 - 10.129.120.x/24 - routers Network one
vlan 121 - 10.130.121.x/24 - routers network two
vlan 10 - 10.129.10.x/24 - users network one
vlan 11 - 10.130.11.x/24 - users network two
and this goes on like this....
what I would like to do is instead of routing on the local switch between vlans I would like then routes to go through the switch. I was told VRF was the way to go, but have no clue on what to do.
when I traceroute between user 1 (10.129.10.5) to user 2 (10.130.121.5) it only has 2 hops, the switch route then the end user pc. I want it to hop from pc1->switch->router->switch->pc2.
can someone point me in the right direction?
thanks
Matt
Re: vrf routing on a 3750
Matt,
you would require to setup MVRF-CE (VRF lite)on the 3750 to do this.
EAch vlan should be a part of a seperate VRF which should be routable via the router.
Is there a specific reason as to why you would not use intervlan routing?
Narayan
Community Member
Narayan,
thanks!
the reason being is that the client only gave us one switch with 2 routers to simulate the MPLS QOS. We needed to seperate the 2 "networks" 10.129 and 10.130, but this morning I got them to release a 2nd switch as it is more like the mirror of the network we are building and not a One-off situation.
thanks again,
Matt
164
