05-14-2012 11:27 PM - edited 03-07-2019 06:42 AM
Hi Expert,
I upgraded IOS-XE on 4500E (SUP7L-E) to cat4500e-universalk9.SPA.03.03.00.SG.151-1. I encounter the log when i try to issue write mem commad
% VRF table-id 0 not activeCompressed configuration from 8947 bytes to 2140 bytes[OK]
How about this message? it's serious log? Thanks
Solved! Go to Solution.
05-22-2012 08:23 AM
Hi Roger,
This mesage is caused by a new bug (not resolved yet) :
CSCtw93140 On 'wr mem' command noticed "% VRF table-id 0" message
Symptom:
Typing wr mem while using an ipbase or lanbase boot level of IOS-XE causes this message to appear on the console .
Conditions:
No specific condition causes this message to appear other than entering the command.
Workaround:
Currently no workaround exists .
According to the current analysis results on this bug, it is seems to be cosmetic.
Kind Regards,
Ivan
**Please grade this post if you find it useful.
05-22-2012 05:35 AM
Hi Experts,
got the same problem (same HW / SW). Additional there is a temporary high CPU and poor reachability using management port fastEthernet1.
05-22-2012 08:24 AM
Hi Odamis,
This is new bug CSCtw93140, not resolved yet but so far seems to be cosmetic. See above for more details.
Kind Regards,
Ivan
05-22-2012 08:23 AM
Hi Roger,
Symptom:
Conditions:
Workaround:
Kind Regards,
Ivan
