vrrp and glbp
carl_townshend
Hi all, are these the same, or is vrrp the same as hsrp ? can you run vrrp on cisco routers ?
Amit Singh
Carl,
they are almost same. HSRP is Cisco proprietry while the VRRP is standard's based.
The major difference that we have is HSRP supports interface tracking while VRRP doesnot support interface tracking.
Another difference is that, in VRRP the standby speaker doesn't send out hellos, while they do in HSRP.
VRRP is supported on Cisco routers starting 12.3/12.4 train
HTH,Please rate if it does.
-amit singh
Amit,
In fact VRRP on 12.4 does support interface
tracking through object tracking, so it makes
it even closer to HSRP now.
Thx,
OW
how would i set my cisco router to use vrrp ?
glbp is load sharing while hsrp and vrrp are not.
