Good day all Experts.
I am a newbie creating a new VRRP environment. R1 and R2 will form VRRP with R1 as the master with priority 110 while R2 as the slave with priority 100.
Every thing is fine when all routers is running up. When R1 is shutdown and R2 took over as master, everything is also fine. However when you shutdown R2 and R1 takes over as master (which is also true since it is configured with a higher priority), then client PC cant ping and pass thru.
Pls help to advice and troubleshoot.
I have configured the environment in GNS3 and can share the DropBox if you provide an email reply.
