05-14-2010 12:47 PM - edited 03-06-2019 11:06 AM
Last week i had the chance to test two 6506 in vss mode.
I made the steps until i got one good virtual switch running.
My first test was to remove the VSL link to see how it goes...
the switches tell me that they were running simplex mode.
I plugged back the vsl link and nothing happened..
they never detected that the vsl link was plugged
i have reloaded both switches several times and never got
back my virtual switch.... always saying vsl link down
if you can help me on this,
thanks
05-14-2010 12:55 PM
You are in dual active mode. Do you have 2 VSL links?
what is the output of "sh swi vir role"?
If you correctly configure VSS and unplug the 2 VSL links after connecting them back the primary switch supposed to reboot.
Reza
05-14-2010 12:59 PM
right after i made the vss setup, i had one active and one standby
then i unplug vsl and when i reconnected the vsl link 5 minutes later
sh swi vir role showed only 1 active switch and nothing else... no standby
i never saw switch reboot
05-14-2010 01:05 PM
If you have configured it correctly the primary should reboot right away after plugging the VLS back into the switch. BTW, the reboot takes about 8 minutes. I actually measured it
05-14-2010 01:10 PM
i have made the basic setup for VSS
no dual active detection and no recovery setup.
any ideas ?
05-14-2010 01:16 PM
did you follow this document to set up?
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.html
05-14-2010 01:21 PM
yes exact.
but i did'nt made the dual active odetection or recovery setup.
05-14-2010 01:37 PM
Try configure them for VSS again. It's also a good idea to double check your port channel configuration.
