Community Member
VSS Dual-Active concept doubt
Hi All
My doubt is about the need of each switch connected to the VSS using L2 or L3 MEC to be ePagp trustable for Dual-Active Detection.
If just one or two of my switches are configured with ePagp and are trustable for Dual-Active Detection, is this enough to the entire VSS realize that it´s in Dual-Active condition and take the action required to stablish the whole enviroment (all switches) ?
Or,
Each switch must have a Dual-Active Detection mechanism in implemented on it, so it can keep working when Dual-Active condition ocour?
Can i use ePagp for some switches and BFD for others (3750 stack) ?
Rafael Giuri
VIP Super Bronze
You just need to enable ePAGP dual active detection on one portchannel that connects to one of your access switch..
dual-active detection pagp trust channel-group xx
Also, you usually run only one method for dual active detection and not ePAGP and BFD as the same time.
They are different, BFD is a direct connection between the 2 VSS switches, but ePAGP uses the access switch.
Community Member
Re: VSS Dual-Active concept doubt
I would also recommend using fast hello as a back up detection for dual active detection.
You can use upto 4 Ethernet connections for this.
I use 2 copper ports in my VSS for this.
208
