Community Member
vss dual supervisor per box
Greeting,
we need help and  documents for hardware and software requirements for configuring vss with dual supervisor per box
Hall of Fame Super Blue
Re: vss dual supervisor per box
m.jawwad@123 wrote:
Greeting,
Mohammad
You can't do this as it is not yet supported with VSS. Cisco have said that it will eventually be supported but as far as i know at the moment you can still only run one supervisor per chassis with VSS.
Jon
VIP Super Bronze
Hi Mohammad,
In addition to Jon's comment, I am tolled by Cisco IOS BU that dual sup for VSS will be available in SXI4.  The release date for it is around July 1st.
Reza
Silver
i gree at this moment dula sup in 1 chassis of VSS is not supported and will be available in the next IOS release
tentative date is july mid if i remember correctly.
Varun
370
