11-26-2013 03:50 AM - edited 03-07-2019 04:47 PM
We have a two 6509 chassis in vss mode (122-33.SXI6).
Currently a 'redundancy force-switchover' takes 10 minutes to complete (before we can access switch on management IP). We are running sso with nsf. Is this expected given standad HSA and we arent/cant run RPR/+.
11-26-2013 07:26 AM
That is not the correct behavior. When you issue "'redundancy force-switchover" it usually takes less than a second for the other switch to take over and become the primary switch. Can you post your config?
11-26-2013 07:32 AM
Also, can you post the output of " show switch virt detail"?
11-26-2013 07:39 AM
Is this what you need ?
MAL2-PR-SW01-1#sh swi virtual role detail ?
| Output modifiers
Switch Switch Status Preempt Priority Role Session ID
Number Oper(Conf) Oper(Conf) Local Remote
LOCAL 1 UP FALSE(N ) 110(110) ACTIVE 0 0
REMOTE 2 UP FALSE(N ) 100(100) STANDBY 8548 2400
RRP Counters:
Inst. Peer Direction Req Acc Est Rsugg Racc
1 1 Tx 0 1 0 1 3
1 1 Rx 2 0 1 0 3
RRP FSM info:
sm(vslp_rrp RRP SM information for Instance 1, Peer 1), running yes, state role_res
Last transition recorded: (lmac)-> lstart (req)-> hold (srt_exp)-> hold (req)-> hold (est)-> role_neg (srt_exp)-> role_neg (racc)-> role_res (srt_exp)-> role_res (racc)-> role_res (racc)-> role_res (srt_exp)-> role_res (srt_exp)-> role_res
In dual-active recovery mode: No
11-26-2013 08:16 AM
just
show switch virtual
or
show switch virtual detail
11-26-2013 08:18 AM
MAL2-PR-SW01-1# sh switch virtual
Switch mode : Virtual Switch
Virtual switch domain number : 100
Local switch number : 1
Local switch operational role: Virtual Switch Active
Peer switch number : 2
Peer switch operational role : Virtual Switch Standby
MAL2-PR-SW01-1#
11-26-2013 04:47 PM
Can you delete this command, save the config and test the fail over again?
switch 1 priority 110
11-27-2013 01:37 AM
It now takes 30 seconds
09-25-2023 11:46 PM
I'm experiencing same issues on our cisco 9500-40x. Any suggestions? to fix
11-26-2013 07:38 AM
09-25-2023 11:46 PM
