Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
VSS IOS upgrade eFSU way - no luck
Am not able to make it happen even though I've got same major release ..
6506-E chasis , SUP2T
SDC2-TP-SW01#sh ver | i IOS
Cisco IOS Software, s2t54 Software (s2t54-IPSERVICESK9-M), Version 15.1(1)SY2, RELEASE SOFTWARE (fc4)
SDC2-TP-SW01#issu loadversion bootdisk:?
bootdisk:s2t54-ipservicesk9-mz.SPA.151-1.SY2.bin
bootdisk:s2t54-ipservicesk9-mz.SPA.151-2.SY.bin
SDC2-TP-SW01#issu loadversion bootdisk:s2t54-ipservicesk9-mz.SPA.151-2.SY.bin
*Oct 18 15:55:18.595: %ISSU-SW1-3-FSM_MISMATCH_MTU: ISSU nego failed for client ISSU VS PROV Client(6047) entity_id 2 session 196878 due to mismatch of mtu size 104 & 152.
*Oct 18 15:55:18.595: %ISSU-SW1-4-FSM_INCOMP: Version of local ISSU client ISSU VS PROV Client(6047) in session 196878 is incompatible with remote side.
*Oct 18 15:55:19.783: %PFREDUN-SW1-6-ACTIVE: Standby initializing for RPR mode
*Oct 18 15:55:24.199: %ISSU_ERROR-SW1-3-MSG_MTU: ISSU VS HA Client(6052): Client failed to get mtu for message 11 (ISSU_RC_NEGO_INCOMP)
SDC2-TP-SW01#sh issu state detail
         The system is configured to be upgraded in staggered mode.
         2 nodes are found to be online.
         Summary: an in-tandem upgrade is in progress.
               Slot = 1/5
           RP State = Active
         ISSU State = Load Version
       Boot Variable = bootdisk:s2t54-ipservicesk9-mz.SPA.151-1.SY2.bin,12;
     Operating Mode = rpr
     ISSU Sub-State = Load Version completed, waiting for system to settle
     Starting Image = bootdisk:s2t54-ipservicesk9-mz.SPA.151-1.SY2.bin
       Target Image = bootdisk:s2t54-ipservicesk9-mz.SPA.151-2.SY.bin
     Current Version = bootdisk:s2t54-ipservicesk9-mz.SPA.151-1.SY2.bin
               Slot = 2/5
           RP State = Standby
       Boot Variable = bootdisk:s2t54-ipservicesk9-mz.SPA.151-2.SY.bin,12;bootdisk:s2t54-ipservicesk9-mz.SPA.151-1.SY2.bin,12
SDC2-TP-SW01#sh issu comp-matrix stored
Number of Matrices in Table = 1
         (1) Matrix for s2t54-IPSERVICESK9-M(10) - s2t54-IPSERVICESK9-M(10)
        Start Flag (0xDEADBABE)
                My Image ver:  15.1(2)SY
                Peer Version    Compatibility
                15.0(1)SY               Incomp(1)
                15.0(1)SY1              Incomp(1)
                15.0(1)SY2              Incomp(1)
                15.0(1)SY3              Incomp(1)
                15.0(1)SY4              Incomp(1)
                15.1(1)SY               Incomp(1)
               15.1(1)SY1              Incomp(1)   why it says incompatinle ???????
                15.0(1)SY5              Incomp(1)
                15.1(2)SY               Comp(3)
I did check that version on Cisco feature navigation and was assured it does support eFSU ?
Any help appreciated....
nsf not enables yet as I have no any uplink/downlink switches attached or any dynamic protocol running. Can it be a culprit ? But why it complains about MTU ?
VIP Super Bronze
Re: VSS IOS upgrade eFSU way - no luck
No you need NSF as you are not running any routing protocols
Is VSS functioning correct?
Do you have 1 sup 2t per chassis?
What is the output of show virtual switch details?
xxxx#sh switch virtual
Switch mode                  : Virtual Switch
Virtual switch domain number : 2
Local switch number          : 1
Local switch operational role: Virtual Switch Active
Peer switch number           : 2
Peer switch operational role : Virtual Switch Standby
WAGRSW01#sh switch virtual redundancy
                  My Switch Id = 1
                Peer Switch Id = 2
    Configured Redundancy Mode = sso
     Operating Redundancy Mode = sso
Switch 1 Slot 5 Processor Information :
        Current Software state = ACTIVE
       Uptime in current state = 4 hours, 20 minutes
Image Version = Cisco IOS Software, s2t54 Software (s2t54-IPSERVICESK9-M), Version 15.1(1)SY2, RELEASE SOFTWARE (fc4)
                          BOOT = bootdisk:s2t54-ipservicesk9-mz.SPA.151-1.SY2.bin,12;
                   CONFIG_FILE =
                       BOOTLDR =
        Configuration register = 0x2102
                  Fabric State = ACTIVE
           Control Plane State = ACTIVE
Switch 2 Slot 5 Processor Information :
        Current Software state = STANDBY HOT (switchover target)
       Uptime in current state = 4 hours, 16 minutes
                   CONFIG_FILE =
                       BOOTLDR =
           Control Plane State = STANDBY
VSS works fine without any issues
And yes , it is 1 sup2t per chassis
Although you have the same major release, you are still jumping a maintenance release version. That is why the compatibility matrix says that the new version you are trying to use in incompatible.
Take a look at the version numbers:
15.1(1)SY2
15.1(2)SY
15.1 is the train. The number in the parenthesis is your maintenance release. In general, for eFSU to work, you cannot jump train numbers or maintenance release numbers.
You will have to manually upgrade your VSS pair without using eFSU/ISSU.
Reference:
http://www.cisco.com/web/about/security/intelligence/ios-ref.html
1469
