VSS on 6513 and 6509
Is it possible to run VSS on one 6513 and one 6509 when considering both has same supervisor engine 2T and same IOS image.
Everyone's tags (1)
1 REPLY
Yes,
It is possible. Chassis can be different as ;ong as each individual satisfy the VSS requirments.
See http://www.cisco.com/en/US/partner/prod/collateral/switches/ps5718/ps9336/prod_qas0900aecd806ed74b.html
"The two physical chassis does not need to be identical in the type of modules installed or even type of chassis. For example, a WS-C6503-E chassis can be combined with a WS-C6513 chassis to form a VSS."
Nik
Pls rate if helpful
290
