VSS on cisco 4507R+E with sup8-E
Hi folks,
I need to configure VSS on cisco 4507R+E switch with SUP8-E,but the problem is that as per the latest relase notes VSS is not supported on sup8-E.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/OL_32143-01.html
Can someone advise me how to proceed?
1 ACCEPTED SOLUTION
VIP Super Bronze
Hi,The links coming from cpe1
The links coming from cpe1 and cpe2 can be bundled and made layer3 port channel on VSS swirtch?
No, the link can't be in a Porchannel as cpe-1 cpe-2 are 2 different devices. If cpe-1 and 2 were for example Cisco 3750 stacked, then yes, you could put both links in a Portchannel on the 3750s and also on 4500 (VSS).
on VSS switch : 172.16.10.6/29 (port channel)
cpe1: 172.16.10.2/29
cpe2: 172.16.10.3/29
HSRP virtual IP: 172.16.10.4/29
All above statements are correct.
Can you eloborate how I can use dot1q encapsulation for this scenario?
Let assume cpe-1 and cpe-2 are Cisco 3845 routers. In this case, you can simply create a sub-interface an each device connecting to the VSS with dot1.q
for example on cpe-1
interface gi0/0
interface gi0/0.10
ip address 172.16.10.2/29
encapsulation dot1q 10
the same thing on cpe-2 except a different IP address.
Now you create vlan 10 with dot1q encapsulation on the 4500 and add it to what ever interfaces that are connecting to the cpes with an ip address on th svi.
or you can keep the 4500 (vss) as layer-2 with no IP and no svi.
it that more clear now?
Reza
Hall of Fame Super Gold
The new 3.6.0E supports Easy
The new 3.6.0E supports Easy VSS for Sup8.
Unfortunately, I have no idea what Easy VSS can/can't do.  It's a new feature.
Thanks Leo! I tried to search
Thanks Leo!
I tried to search for some documents on Easy VSS, have not found yet.Any links to Easy VSS would be a great help.
Any idea if I have to upgrade IOS ver form 15.2(1)E to 15.2(2)E for Easy VSS to work ?
Personally, I'd WAIT.  This
This is the first IOS which supports Easy VSS.  All of us don't know what bugs lurk beneath, unless you want to be the "guinea pig".  wink
Cisco's quality control, when it comes to the stability of their IOS codes, have taken a significant "hit" for the last two years.  Bugs that should've been picked up early on, prior to public release, weren't.
Thanks Leo,I better go with
Thanks Leo,
I better go with sup7-E.
Btw, can you please give me a idea about layer 3 MEC on VSS switch.
I need to connect  VSS switch to two CPE routers running HSRP and I have /29 IP subnet for it.
Can I create Layer 3 portchannel on VSS switch and terminate the links to CPE's, keeping all of them in the same subnet and putting a static route to HSRP virtual address?
Please advise.
VIP Super Bronze
Hi,Yes, layer-3 Portchannel
Yes, layer-3 Portchannel/MEC is supported with VSS. Also, connecting you VSS to 2 CPE routers with HSRP or VRRP should work just fine. For example: you connect cpe-1 to 4500-1 and cpe-2 to 4500-2.  Now you need a /29 or /28 with a vlan and dot1q tagging (or could be access port) to span from cpe-1 to 4500-1 over the VSL link to 4500-2 and cpe2. I personally like to use dot1q, so in the future if I need to add another vlan, I don't have to have an outage to change the port from access port to trunk.
Hi Reza, The links coming
Hi Reza,
Thanks in advance!
VIP Super Bronze
interface gi0/0
interface gi0/0.10
Reza
It is much clear now.. Thanks
It is much clear now.. Thanks :)
Hi, I have upgraded 4507R+E
I have upgraded 4507R+E switch with the latest IOS release(ROM: 15.1(1r)SG4,  ver 03.06.00.E release software) and it supports VSS.
Another problem here is SSH is not supported. Any idea what can be done as this is the latest software release.
Hi,I am not able to find any
I am not able to find any SSH commands on switch, Any ideas for the above
Easy VSS is just VSS
Easy VSS is just VSS configuration with one command instead of bunch of commands.
The configuration guide you may find here:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/XE3-6-0E/15-22E/configuration/guide/xe-360-config/vss.html#pgfId-1130268
Cool! The documentation for 3
Cool!
The documentation for 3.6.0E is finally coming out.
869
