VSS PRIORITY
sreeju balan
i have 2 6500 series switches running vss, can i use same vss priority for both switches in the vss domain
6 Replies 6
Ganesh Hariharan
Check out the below link for your query !!
http://www.netcraftsmen.net/component/content/article/69-data-center/749.html
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Dear Ganesh,
Very nice document..Thanks a lot
But what cisco recommends for the priority configuration for vss? do you have any idea
Thanks for your support
Dear Ganesh,
Ok,
The priority tells which will begin as the  active supervisor.
Check out the best practices for VSS deployment by cisco
http://www.cisco.mn/web/DK/assets/docs/presentations/VSS_0109.pdf
Hope to Help !!
Ganesh.H
Hi Sreeju,
Cisco or at least our SEs do not recommend priority and preemption.  We also have done some testing with it. It gets very confusing to keep track of primary and backup switch when there is a failure.  The VSS pair becomes some what unpredictable when using priority and preemption since it cause the devices to reboot.
Reza
smalep
In the original Cisco VSS implement document they did suggest using priorities but that is no longer recommended and therefore should be avoided.
I would suggest not setting the priority.
graham smart
Hey,
We dont bother having different priorites or preempt either.
I cant see any reason for having a "master" as it shouldnt matter what switch is active at any one time.
VSLP tends to resolve whos going to be master happily. Just remember to have dual active crosslinks.
Switch  Switch Status  Priority     Role    Session   ID
        Number         Oper(Conf)           Local    Remote
LOCAL    2     UP       100(100)    ACTIVE   0        0
REMOTE   1     UP       100(100)    STANDBY  6991     2069
-Graham
Please note: My comments are simply suggestions. I cannot be held liable for any loss of data, life or marbles due to following my instructions.
Got a website? Need some live chat software?
