Webcast-Catalyst9k
VSS sup module
 Say i have two core swiches with each on with a VSS Sup 720-10G, if the VSS supervisor 720-10GE dies on one of the core switch does the core switch with still good VSS Sup 720-10G support all the routing, etc for both core switches?
Hall of Fame Super Blue
No it doesn't.Each switch can
No it doesn't.
Each switch can forward data as long as the supervisor in each switch is up.
If the supervisor in a switch fails then the whole switch fails. The other switch can still forward traffic and all traffic would now go via this switch.
But the switch that is still up will not take over the linecards in the failed switch. They will be down until the failed switch has a working supervisor.
Jon
Super Bronze
DisclaimerThe Author of this
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
BTW, the exception to what Jon describes, is, if 6500 VSS members have a 2nd sup.  Newer IOS versions, when running VSS, support sup redundancy within the same chassis.  If there are two sups with the chassis, and both fail, then as Jon described, that VSS member would "die".
27
