VSS Switch showing very higu CPU continue
We are facing issue of getting very high CPU utilization for the VSS Switch model WS-C6509-E some times approx 100%.
Attaching here show tech-support taken later after CPU normal along with show logging, show cpu sorted.
HCAINNOI01XXXCS0001#sh proces cpu | ex 0.0%
CPU utilization for five seconds: 100%/13%; one minute: 90%; five minutes: 91%
PID 5Sec 1Min 5Min Process
16406 91.2% 75.2% 76.2% ios-base
16426 1.7% 1.4% 1.4% udp.proc
16429 0.3% 0.3% 0.3% raw_ip.proc
16432 2.8% 3.1% 3.1% cdp2.iosproc
Please suggest me on this VSS switch issue  if getting some clue from the logs attached.
Ashutosh
Hall of Fame Super Bronze
Post the output from show process cpu detailed
Re: VSS Switch showing very higu CPU continue
Hi Edison,
       Attached is the sh tech containing the sh process cpu detailed, please go through the same and let us know..
Thanks..
Jyotiraj..
Jyotiraj,
Based on your show tech:
------------------ show process cpu detailed ------------------
CPU utilization for five seconds: 90%/16%; one minute: 58%; five minutes: 38%
PID/TID   5Sec    1Min     5Min Process             Prio  STATE        CPU
1        15.0%    1.9%     0.6% kernel                                 5h53m
      1   9.7%   42.5%    61.8% [idle thread]          0  Ready       58d03h
16406    68.1%   46.5%    30.2% ios-base                              18d23h
Process sbin/ios-base, type IOS, PID = 16406
CPU utilization for five seconds: 65%/16%; one minute: 27%; five minutes: 11%
   9       16011      8529   1877  54.67% 19.20%  4.67%   1    M Virtual Exec
The biggest offenders are your telnet/ssh session because a show tech was executed and the [idle thread].
[idle thread] is part of the modular IOS service and should not present an issue.
If you want correct CPU reporting, I suggest migrating to a non-modular IOS.
Edison
Please remember to rate helpful posts.
669
