VSS with dual supervisor in each chassis
jackson.ku
Level 3
Level 3
VSS doesn't support dual SUP in each chassis right now. What happen if I install dual SUP in each VSS chassis?
Does anyone know the roadmap when and which new IOS can support?
Best Regards,
Jackson
Giuseppe Larosa
Hello Jackson,
that you are going to look for troubles.
best case:
second supervisor is held down
worst case:
it causes problems
the feature can be in the road-map no more detailed info up to know
Hope to help
Giuseppe
Thanks a lot...
Support for dual supervisors and VSS is on the roadmap for the next software release, expected H2Y2010 hopefully...
