03-22-2010 09:51 PM - edited 03-06-2019 10:15 AM
VSS doesn't support dual SUP in each chassis right now. What happen if I install dual SUP in each VSS chassis?
Does anyone know the roadmap when and which new IOS can support?
Best Regards,
Jackson
03-23-2010 03:41 AM
Hello Jackson,
that you are going to look for troubles.
best case:
second supervisor is held down
worst case:
it causes problems
the feature can be in the road-map no more detailed info up to know
Hope to help
Giuseppe
03-23-2010 06:21 AM
Thanks a lot...
03-24-2010 02:27 AM
Support for dual supervisors and VSS is on the roadmap for the next software release, expected H2Y2010 hopefully...
