Webcast-Catalyst9k
VSS with dual supervisor in each chassis
VSS doesn't support dual SUP in each chassis right now. What happen if I install dual SUP in each VSS chassis?
Does anyone know the roadmap when and which new IOS can support?
Best Regards,
Jackson
Hall of Fame Super Silver
Re: VSS with dual supervisor in each chassis
Hello Jackson,
that you are going to look for troubles.
best case:
second supervisor is held down
worst case:
it causes problems
the feature can be in the road-map no more detailed info up to know
Hope to help
Giuseppe
Thanks a lot...
Bronze
Support for dual supervisors and VSS is on the roadmap for the next software release, expected H2Y2010 hopefully...
708
