VTP - 2 servers trunked together
I am just walking into an undocumented environment and ran across this and want to see what you guys think.
I have a 3550 that shows it is the server for the vtp domain 'foo'. Connected to it via a trunked port, is a 2950 that is also a server of the vtp domain 'foo'. Everything is working. What is going on here? I thought you couldn't have 2 servers in the same domain. Also, the configuration versions match. Any ideas?
Re: VTP - 2 servers trunked together
Hi Friend,
You can definetely for sure have more than 1 VTP servers in your network and infact bydefault the VTP mode is set to server for all the switches.
It is also recommended to have more than 1 VTP server in network incase if your one VTP server goes down you still be having another one to hold your network.
Ankur
*Pls rate all helpfull post
Hi Friend,
You have can 2 VTP servers in a VTP domain and can co-exist together in a LAN. Infact it is a good Idea to have a VTP server redundancy in a LAN so that if one of the server fails there shouldnot be any VLAN database corruption issue which can bring the entire LAN down.
The VTP versions should MATCH in a VTP domain as both the verions are incompatible.
HTH, Please rate if it does.
-amit singh
That answers a few of my questions. However, 1 more. How do I "force" a replication? I have a switch that is being stubborn and won't get the configuration.
Purple
Check the vtp domain name and password if there is one . What kind of switch is it ?
170
