VTP and VLAN
I'm using a VTP configuration on my switches but only the VLAN's name was exported, not the port's configuration
1 REPLY
Re: VTP and VLAN
That is correct. VTP is used for VLANs, not ports. You can either configure all ports at once with the interface range command or use smartports.
http://www.cisco.com/cdc_content_elements/flash/smartPorts/index.html?NO_NAV
Hope that helps.
210
