Community Member
VTP BLK meaning
can anyone explain what this means: * LOOP
Gi3/15Desg BKN*3004128.143 P2p *LOOP_Inc
Re: VTP BLK meaning
The port is in a Loop inconsistent state.
Community Member
Re: VTP BLK meaning
How does one resolve this inconsistentcy
Re: VTP BLK meaning
Error Message: SPANTREE-2-LOOPGUARDBLOCK: No BPDUs were received on port [chars] in [chars] [dec]. Moved to loop-inconsistent state
Explanation: This message indicates that due to a unidirectional link failure, or failure of a bridge, BPDUs are not being received on the port. Loopguard has blocked the port to prevent loops.
Check the bridge connected to this port and test the link for any unidirectional failures. Sometimes excessive delay between BPDUs can trigger this event. If this is the case, no action is required because the port state is restored with the arrival of the next BPDU.
Community Member
Re: VTP BLK meaning
It appears to move from one vlan to another do you think this could affect performance
191
