02-12-2007 09:57 AM - edited 03-05-2019 02:18 PM
Hi Expert,
I have a VTP concept want to clarify.
VTP is classified as server, client and transparent. As I know, server will advertise and receive Vlan information within the VTP domain, and client mode will only receive Vlan information from server within the same VTP domain. Am I right ? is it mean that if server mode switch with VTP domain "testing" has Vlan 2, 3, 4 . Then those client mode swich with VTP domain "testing" can receive Vlan 2, 3, 4 and generate Vlan database automatically.
Thx !
Solved! Go to Solution.
02-12-2007 10:07 AM
You are correct in what you say. If a switch is set to vtp client and it has the same vtp domain (and optionally password) as the vtp server then if you add a vlan on the switch which is the vtp server it will propogate to the client switch. You can then allocate ports on the client switch into that vlan.
Just for completeness a switch set to transparent will not update its database with a vlan that has been created on a vtp server switch but if there is a client vtp switch further down the path it will forward the vtp update on and the client will then update it's database.
Jon
02-12-2007 10:07 AM
Jon
