VTP Domain Failure
I have a WS-C2950-24 that does not read the VLAN domain from its VTP Server, this is the output:
sh vtp status
VTP Version : 2
Configuration Revision : 0
Maximum VLANs supported locally : 64
Number of existing VLANs : 7
VTP Operating Mode : Client
VTP Domain Name : XXX
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
MD5 digest : 0xB6 0xC2 0x8B 0xBB 0x79 0x5D 0x0A 0x93
Another Output:
sh vlan
VLAN Name Status Ports
1 default active
4 VLAN0004 active Fa0/12, Fa0/21, Fa0/22, Fa0/23
12 VLAN0012 active Fa0/1, Fa0/2, Fa0/3, Fa0/4, Fa0/5, Fa0/6, Fa0/7, Fa0/8, Fa0/9, Fa0/10, Fa0/11
Fa0/13, Fa0/14, Fa0/15, Fa0/16, Fa0/17, Fa0/18, Fa0/20
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
4 enet 100004 1500 - - - - - 0 0
12 enet 100012 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - - 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
Remote SPAN VLANs
Primary Secondary Type Ports
Re: VTP Domain Failure
Eloy,
There could be several reasons for this.
1. Check if you have the same domain name configured on all the switches.
2. Check if your trunk ports are properly comfigured and working fine.
3. Check if there is any VTP password configured on the VTP server and has to be same on the VTP domain clients. To check this compare " show VTP counters " on both the switches and see if you are getting any " message digest errors ".
Please paste the switch configurations and also " show VTP status " and " Show VTP counters " from both the switches.
HTH,Please rate if it does.
-amit singh
Purple
As Amit indicated the usual reasons are that the vtp domain name and if it has a password do not match exactly . They must match exactly including upper and lower case .
110
