VTP is not working through a wireless link
Siamak.Mianji
I have a 3524 switch that is connected to corporate network and an acess point (AIR-BR1410A) this AP is connected to another AP (the same model) by wireless and the second AP is connected to a 2950 switch. both switches are VTP lient. the first switch gets all VLAN information by VTP but the second one dose not. the ports those connected to AP's is in trunk mode, 802.1Q. VTP domain and password are same in all switches.
Thank you
Siamak
8 Replies 8
balajitvk
Level 4
Level 4
Could u specify the version of IOS in Aironet Root Bridge APs???? What is the natvie vlan being used??? VLAN 1 or something other..... There was IOS caveats were there and the same seems to be resoved in 12.3(2)JA version.
CSCeg12593?Bridges now pass VTP information when the native VLAN on the bridge is not VLAN 1.
Rate if it does,
Rgs
Rgs,
12.3(7)JA3
Cheers,
The native vlan is 1. Should I change it to something else?
Siamak
Siamak,
No, you should be fine with the native vlan. Could you please post the trunk config from the both the switches. Also " Show VTP Status " and " Show VTP counters".
-amit singh
[corporate LAN]------[SW1 - f0/3]--[AP1] - - - - - [AP2]--[f0/12 - SW2]
SW1#sh inter fa 0/3 status
Port Name Status Vlan Duplex Speed Type
Fa0/3 connected trunk A-Full A-100 100BaseTX/FX
SW1#sh vtp status
VTP Version : 2
Configuration Revision : 30
Maximum VLANs supported locally : 254
Number of existing VLANs : 22
VTP Operating Mode : Client
VTP Domain Name : SMM_DO
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
MD5 digest : 0x18 0x25 0x64 0xF6 0xD8 0xB0 0x00 0xFD
Configuration last modified by 127.0.0.52 at 7-27-07 04:39:37
SW1#sh vtp counters
VTP statistics:
Summary advertisements received : 9035
Subset advertisements received : 23
Request advertisements received : 41
Summary advertisements transmitted : 26217
Subset advertisements transmitted : 81
Request advertisements transmitted : 40
Number of config revision errors : 0
Number of config digest errors : 0
Number of V1 summary errors : 0
VTP pruning statistics:
Trunk Join Transmitted Join Received Summary advts received from
non-pruning-capable device
Fa0/1 0 0 0
Fa0/2 0 0 0
Fa0/3 0 0 0
Gi0/1 0 0 0
SW1#sh int fas 0/3 acc
FastEthernet0/3
Protocol Pkts In Chars In Pkts Out Chars Out
Spanning Tree 40 1485 3948322 247402392
CDP 43464 15212385 43467 16778238
VTP 4652 426126 5140 536390
************ SW2 (dosn't have VLAN info) *************
SW2#sh int trunk
Port Mode Encapsulation Status Native vlan
Fa0/11 on 802.1q trunking 1
Fa0/12 on 802.1q trunking 1
Port Vlans allowed on trunk
Fa0/11 1,200
Fa0/12 1,200
Port Vlans allowed and active in management domain
Fa0/11 1
Fa0/12 1
Port Vlans in spanning tree forwarding state and not pruned
Fa0/11 1
Fa0/12 1
SW2#sh vtp status
VTP Version : 2
Configuration Revision : 0
Maximum VLANs supported locally : 128
Number of existing VLANs : 5
MD5 digest : 0xEC 0x64 0xE3 0xE7 0xF9 0x78 0xD3 0x0F
Configuration last modified by 106.149.14.55 at 7-27-07 02:50:30
SW2#sh vtp c
VTP statistics:
Summary advertisements received : 0
Subset advertisements received : 0
Request advertisements received : 0
Summary advertisements transmitted : 1771
Subset advertisements transmitted : 42
Request advertisements transmitted : 100
Fa0/11 0 0 0
Fa0/12 0 0 0
SW2#sh int fas 0/12 acc
FastEthernet0/12
Spanning Tree 333120 19319916 1 60
CDP 5523 1933050 5525 2259669
VTP 0 0 960 96016
Siamak,
You trunk config and the VTP config looks fine and there is no issues with that.
I did som research on this and came across a bug with is integrated in 12.3.7 series of IOS.
Bug ID is : CSCsc88624
Non-root bridge modifies VTP packets from SNAP format to DIX format. It causes VTP
clients not to update the VLAN database if the wireless bridge is the only link between VTP
server and the VTP clients.
The Fixed for this Bug is in 12.3(8)JA2.
I would suggest you to upgrade the AP's to atleast 12.3(8)JA2 and check if it solves the issue.
HTH,Please rate if it does.
-amit singh
Thank you very much Amit.
