01-28-2008 11:20 PM - edited 03-05-2019 08:46 PM
Hi NetPro,
currently i am running in Flat Network 2 Tier. only 1 Vlan used for entire network. unfortunately 5 switches all running in vtp server mode. would it be possible i configure the domain name and change the vtp mode to client/transparent (4 switches) without any down time ?
thanks and your reply will be highly appreciated.
regards,
jack
01-28-2008 11:34 PM
of course u can, u can setup your switch in vtp client or transparent or in diff name domain.
01-28-2008 11:49 PM
Hi ,
thanks for reply, these switches are in live.
my question was can i change the vtp mode from server to transparent without causing any downtime or impact to servers, end users .. etc.
thanks.
regards,
jack
01-29-2008 12:04 AM
hi,
since you are using only one vlan in your entire network there will be no harm creating a VTP transperent mode from server mode.
The general practice say that you need to configure all the vlans on the switch you intend to use as a VTP server and choose the switch with higher revision number as a VTP server.Or change all the switches to transperent mode (this causes the revisoin number to become zero) then configure all vlans on the switch you want to be as a server.Then change the switch to server and cleint mode accordingly.
HTH,
regards,
shri :)
01-29-2008 12:43 AM
Hi Shri,
thanks for the information.
regards,
jack
