Community Member
vtp pruning 问题??
书上说vtp transparent 不支持 vtp pruning,在执行vtp pruning的网络里加入transparent mode的交换机会使网络不稳定,要求在全网关闭pruning 或关闭 transparent switch 下面switch的vlan pruning。
问题:为什么会引起不稳定?
      我实验A-B-C, A 是vtp server, B是vtp transparent mode, C是vtp client,在A和C上起SVI,在A  上起vtp pruning,A和C 仍能通信,为什么并没有影响网络?
1 ACCEPTED SOLUTION
Re: vtp pruning 问题??
Hi ZhiWei,
vtp prunning 只是在vtp server/client模式下才起作用。transparent 模式需要手动配置prunning,通过在端口配置allow vlan。在vtp prunning的网络中加入vtp transparent的交换机可能会造成网络问题。按照你的例子sw1 - sw2 - sw3, sw1是vtp server,sw3是vtp client,sw2是vtp transparent,sw1启用vtp prunning。假设sw3上有vlan 1,2,sw2有vlan 1,2,3,sw1有vlan 1,2,3。因为vtp prunning,sw3会告诉vtp server只需要vlan1和vlan2的数据;sw2虽然不参加vtp prunning但是它会转发vtp prunning到sw1,sw1从sw2收到vtp prunning的包。这时候在sw1和sw2之间的 trunk,vlan 3会被pruned。
HTH,
Lei Tian
Community Member
Will it be possible to convert in English and define what you expect?
Shailesh
Hi ZhiWei,
HTH,
Lei Tian
Community Member
sorry dear, but what so ever you are pasting  - the font is not supported and i am getting symb
olic view..
Can you copy the same in notepad and share as an attachment?
With regards,
Shailesh
857
