Webcast-Catalyst9k
VTP Pruning help
Here is my Show vtp status
VTP Version : 2
Configuration Revision : 27
Maximum VLANs supported locally : 1005
Number of existing VLANs : 14
VTP Operating Mode : Client
VTP Domain Name : Company
VTP Pruning Mode : Enabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
Here is my show int trunk
Port Mode Encapsulation Status Native vlan
Fa0/2 on 802.1q trunking 1
Po2 on 802.1q trunking 1
Port Vlans allowed on trunk
Fa0/2 1-4094
Po2 1-4094
Port Vlans allowed and active in management domain
Fa0/2 1,10,20,40,60,80,140,150,160,200
Po2 1,10,20,40,60,80,140,150,160,200
Port Vlans in spanning tree forwarding state and not pruned
All the ports on this switch are in Vlan 60, why isnt pruning working ?
Port fa0/2 is a trunk to my Wireless Access-point
1 ACCEPTED SOLUTION
Super Bronze
Re: VTP Pruning help
Is this output from the switch you believe should have pruned the VLANs? (i.e and edge switch)?
If so, your fa0/2 port configured as a trunk will be sending out all VLANs (as the AP will not participate in VTP) so none will be pruned.
Setting a VLAN-allowed list on the fa 0/2 port may rectify it in this case.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Super Bronze
Aaron
Its like this
Core - (Po2)This Switch(f0/9) - Wireless AP
It is the Edge Switch.
The Wireless AP is confgiured for VLan's 140,150,160
The management vlan is 1
SO your saying I can do:
interface f0/9
switchport trunk allowed vlan 1,140,150,160
This will fix the problem ?
Cool that fixed it.
183
