12-06-2013 03:05 AM - edited 03-07-2019 04:57 PM
Does VTP pruning request goes through the interface that is blocked by the STP?
Solved! Go to Solution.
12-06-2013 03:56 AM
STP blocked ports send and receive VTP Join Messages [*]:
You can see that VLAN 2 is pruned on the respective port of the neighbor switch.
([*]: The VTP Pruning is internally provided by switches exchanging periodic VTP Join messages that contain a list of all VLANs and their used/unused status.)
Rolf
12-06-2013 03:56 AM
Rolf
