07-02-2007 12:36 AM - edited 03-05-2019 05:04 PM
hi all.
Well if there are 2 vtp server present in the same domain ,whoe will be sending the VTP advertisement for the domain?
If the answer is both,which VTp advertisement the client take the one that will rech it first or the one from the higher IP?
07-02-2007 12:45 AM
Both servers can originate the VTP advertisements, and the client will finally accept the higher revision number advertisement, further on the whole domain (servers and clients) should be updated with the highest revision number advertisement.
HTH,
Mohammed Mahmoud.
07-02-2007 02:18 AM
thanks for the reply..well my doubt was that both the server have same CNR.
07-02-2007 02:25 AM
As mahmoud said all the switches in the vtp domain should have the same CNR,if any of the switch doesnt have the same CNR it means that it doesnt have the current vlan database information.
Mahmood
07-02-2007 02:58 AM
As Mahmood has stated, at steady state all the switches should have the same revision number, the higher revision number updates the lower revision number until all the switches have the same revision number.
HTH,
Mohammed Mahmoud.
