Webcast-Catalyst9k
vty config question
Hi All,
I saw a config on a router that looked something like below.  My question is what function does the "no login" command have?
line vty 0 4
  password C1cs0
  no login
Thank You - Joe
2 ACCEPTED SOLUTIONS
Gold
vty config question
To enable password checking at login, use the
login
command in line configuration mode. To disable password checking and allow connections without a password, use the
no
form of this command.
vty config question
You can tell your router/switch to allow the Telnet connections without a password by using the "no login" command.
Generally, we dont recommend using the "no login" command to allow telnet connections without a password unless you are testing something. In production network you shoud always set your vty password for security purposes.
Sweta
Please rate useful posts.
Gold
vty config question
login
no
vty config question
Sweta
vty config question
thank you
vty config question
thank you
180
