VXLAN nexus 1000v
can I install the vem on hosts that are across a wan in another datacenter (subnet)
If so does the vxlan feature need to be enabled for it to work?
1 REPLY
Hi Tony,You are able to do
Hi Tony,
VXLAN is not a requirement for this solution.
You are able to do this if the SVS mode is L3, which is the default mode starting in SV2(1.1). However, latency needs to be taken into consideration. That latency limit is 10ms.
Here is the solutions guide for Stretched Nexus 1000v Model.
Other literature:
  • Cross Data Center High-availability – Supports split Active and Standby Nexus 1000V Virtual Supervisor Modules (VSMs) across two data centers to implement cross-DC clusters and VM mobility while ensuring high availability. In addition, VSM’s in the data center can support VEM’s at remote branch offices.
(source: https://blogs.cisco.com/datacenter/the-next-evolution-of-ciscos-nexus-1000v-virtual-switch-to-be-featured-at-vmworld/)
HTH,
Joe
55
