08-31-2007 09:34 AM - edited 03-05-2019 06:13 PM
I am currently doing a demo with the WAE 612 running inline. The appliances are running the latest code (4.0.13.b.12 ). One the core side we have the WAE between our ASA 5510 running 8.0 and our 3825 and on the edge side we have a WAE between our 2811 router(12-4.15T) and switch. Both WAE's are running an in-line. I have been working with the local Cisco engineers and we can't not determine why the traffic between the core and edge is not being optimized. The management WAE has access to both WAE's and all WAE's are online but there is no optimization.
09-20-2007 08:01 PM
Ironically, I'm running demo at 4.0.13.b.12 and I'm not optimizing either. Did you ever get this fixed? If so, what was the cure?
09-21-2007 04:14 AM
What is the topology of your network at the site where your core-wae and wae manager is located? We are running the WAE-core in an in-line configuration behind the ASA. At the branch we are running as a test a WAE also inline between our 2811 router and switch. There are certain IOS versions that you must be running on the ASA and router to make this work along with some configs.
09-27-2007 11:50 PM
From what you are telling me I don't exactly understand where you've positioned the WAE's but this is what the WAE's do to detect if the connection needs to be optimized:
They add a specific IP option to the IP packet traveling through the first WAE. The remote WAE should see this IP option and reply add the same option to the return traffic. At the same time the WAE's shift the tcp sequence numbers on the packets that traverse the WAE's on one side and de-shift it at the second WAE.
So unless the WAE's see the IP option and continue to see the correct sequence-number shift, the connection will not be optimized.
Keep in mind that ASA's and IOS firewalls might not understand the IP option and/or sequence number shift and remove the option or drop te connection.
ASA 7.0 (I haven't checked 8) does not understand these options and seq-nr shifts. I don't know for IOS firewall, but the same might apply.
10-12-2007 11:03 AM
etamminga is mostly correct. And, I agree that the original post did not clearly identify the topology. I have a pair of WAE's running as legs off of routers(using WCCP), and traversing thru ASA's with an IPsec tunnel between them.
Almost a year agao, we installed them. After opening a TAC case to address the non-optimization, ASA special code was created to properly execute the needed code - I am running version 7.2(2)12, but I don't know if any other later version includes the fix it (even 8.0).
In case you or anyone else wants the info, the ASA config that is needed is in two parts:
1) Most people would want to do nonat (aka nat-zero), but that does not work. And, you need several specific options that are only on the static command AND use it both directions, on both firewalls. These options are:
nailed - Allows TCP sessions for asymmetrically routed traffic
norandomseq - Disables TCP ISN randomization protection
For one ASA, for the far end segments use
static (outside,inside) far-end far-end netmask x.x.x.x norandomseq nailed
And, repeat for every segment range/mask required.
For the local, you'll need to use an access-list and the static nat:
access-list stat-acl-name extended permit ip local-sement-1 local-seg-mask object-group FAR-END-SEGMENTS
static (inside,outside) local-segment-1 access-list stat-acl-name norandomseq nailed
And, repeat the pair for every local segment.
2) need to allow 33 in the tcp-options. This is what the WAE set so they recognize their streams. To do this, requires several steps:
access-list TCP-Options-ACL extended permit tcp any object-group FAR-END-SEGMENTS
access-list TCP-Options-ACL extended permit tcp object-group FAR-END-SEGMENTS any
tcp-map WAAS-Options-map
tcp-options range 33 33 allow
class-map MATCH-TCP-Options-map
match access-list TCP-Options-ACL
policy-map global_policy
[perhaps other class'es for default inspection}
class MATCH-TCP-Options-map
set connection advanced-options WAAS-Options-map
service-policy global_policy global
Hope this helps!
