11-07-2014 06:39 PM - edited 03-07-2019 09:25 PM
Hi everyone,
I have configured 3750 switch as WCCP.
I am redirecting only inside traffic.
Switch has direct connection to Mcafee Gateway.
Our internal LAN subnets are 172.16.x.x and 192.168.0.0.
Need to confirm if i want internal users to access the internet then under permit ACL i can say
permit 172.16.0.0 to any?
If i want some users traffic should not be redirected to Mcafee gateway then i can say
deny 172.16.10.10 any?
MAhesh
Solved! Go to Solution.
11-07-2014 06:57 PM
Yes, you should be able to do that with no issue...
HTH,
John
11-07-2014 06:57 PM
HTH,
John
11-07-2014 07:12 PM
Thanks John i will do that.
MAhesh
11-09-2014 06:27 PM
Note: you'll need to be running at the very least 12.2(58)SE for deny ACL support in WCCP. Prior to this only permit ACL entries were supported.
11-10-2014 06:03 PM
Hi Reuben,
Yes IOS version is higher than 12.2(58)SE.
Thanks for reply.
MAhesh
