Community Member
WebUI,telnet not working on Cisco 2960
hi...i have given a uplink to cisco 2960 switch which in turn is uplink to another switch(2960)..now my problem is that i m able to access the second switch(telnet,WebUI) but not the first switch...cannot guess wat might be the problem...bcoz if the second switch is working then it is recieving connection from first switch...wat shud i do?..help
Silver
Re: WebUI,telnet not working on Cisco 2960
First check the connection between the switch its configured properly and its passes all the traffic between the device and trunk settings established properly . It may be misconfiguration ie speed and mode.
Purple
Please post configs of both boxes...
365
