08-08-2008 07:07 AM - edited 03-06-2019 12:41 AM
I'm using the CCO online Bug Toolkit and scrubbing an IOS. In previous IOS's the bug appeared and so I was trying to determine when the bug was fixed. Information on the bug itself (CSCsk80659) doesn't show a 'fixed in' version. Yet when scrubbing IOS 12.4(19) and 12.4(19a), it shows up in the former, but not in the latter. In fact, in the latter, it doesn't show up at all even though I'm looking at all categories (shouldn't it show up as either fixed, or terminated?) The bug itself is "more info required" state.
This is an example of a larger question: if I look at 12.4(19) there are 90 open bugs listed. If I look at 12.4(19a), there are only 52 in open, fixed, or terminated state. What happened to the other 38 bugs? (search is all IOS, no restriction on hardware, and searching back 1 year (max possible)).
Solved! Go to Solution.
08-14-2008 11:28 AM
I think the work may be in progress in 12.4(19a) release so later probably the bugs may be added.
08-14-2008 11:28 AM
