12-10-2013 06:53 AM - edited 03-07-2019 05:00 PM
If the configuration between two sites is like below, how can i tell the routes to the routers?
Please don't mind if it is silly or i'm missing some basics.
Chandu
Solved! Go to Solution.
12-10-2013 07:07 AM
NAT for overlapping subnets might be a solution for you?
See
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080093f30.shtml
for details.
Best regards,
Milan
12-10-2013 07:13 AM
There are no such thing as silly questions
You seem to have the same subnet (10.0.1.0 /24) on both sides which will not work as they are separated by a router...or two routers in this case.
When a Router recieves a packet, it does a lookup in its routing table for the destination IP address.
In your example, how would the Router know where to forward the packet if the 10.0.1.0 /24 subnet exists on both sides?
12-10-2013 07:07 AM
See
for details.
Best regards,
Milan
12-10-2013 07:13 AM
12-10-2013 08:50 PM
Got it.
So with the help of natting this is possible.
Chandu
12-10-2013 11:25 PM
Yes,
that's possible.
But I'd use this solution as a last chance only in a case it's absolutely impossible to readdress one of those subnets.
IMHO, it's much easier to change an address of one /24 subnet than to run two subnets with overlapping addresses for a long time.
Users will totally be confused by the same addresses on both sites and any troubleshooting would be a nightmare.
Best regards,
Milan
