Weird stack issue? Conflicting after re-number
cshannahan
So I have 2 switches in this 3750 stack.  The 12S was switch 2 (Master) and the other is switch 3 (member).  I'm getting ready to add another 12S to the picture. I wanted to make the current switch 2, switch 1.  So I renumbered it and rebooted it.  It now has 3 switches listed.  I haven't added the 2nd Fiber switch to the stack yet until I get this cleared up.  Check out what has happened below!  Notice the conflicting information between the running config and the sh int status command!
I wanted switch 2 to be switch 1...it seems like half of it worked!  I don't know what to even do here!  I think I might renumber switch 1 back to switch 2 and make the new fiber 12s switch1.  Any idea why this didn't just make switch 2 into switch one and take the configuration with it?  I'm so confused with the conflicting info.
Admin-SW01#sh run
switch 1 provision ws-c3750g-12s
switch 2 provision ws-c3750g-12s
switch 3 provision ws-c3750-24p
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet2/0/1
description EX
switchport access vlan 225
switchport mode access
spanning-tree portfast
interface GigabitEthernet2/0/2
description JP
switchport mode trunk
interface GigabitEthernet2/0/3
description MRM
duplex full
interface GigabitEthernet2/0/4
description MRM
interface GigabitEthernet2/0/5
description MRM-Mine
interface GigabitEthernet2/0/6
description MRM445
interface GigabitEthernet2/0/7
switchport access vlan 753
shutdown
interface GigabitEthernet2/0/8
shutdown
interface GigabitEthernet2/0/9
shutdown
interface GigabitEthernet2/0/10
shutdown
interface GigabitEthernet2/0/11
shutdown
interface GigabitEthernet2/0/12
interface FastEthernet3/0/1
description
shutdown
interface FastEthernet3/0/2
description
ETC to port 3/0/24
MRM-Admin-SW01#sh switch detail
Switch/Stack Mac Address : 001b.8f78.e680
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master 001b.8f78.e680     15     0       Ready
2       Member 0000.0000.0000     0      0       Provisioned
3       Member 001a.a2a0.b580     1      0       Ready
MRM-Admin-SW01#sh int status
Port      Name               Status       Vlan       Duplex  Speed Type
Gi1/0/1                      connected    1          a-full a-1000 1000BaseLX SFP
Gi1/0/2                      connected    trunk      a-full a-1000 1000BaseLX SFP
Gi1/0/3                      connected    trunk      a-half  a-100 100BaseFX SFP
Gi1/0/4                      notconnect   1            auto   auto 1000BaseLX SFP
Gi1/0/5                      connected    trunk      a-full a-1000 1000BaseLX SFP
Gi1/0/6                      connected    trunk      a-full a-1000 1000BaseLX SFP
Gi1/0/7                      notconnect   trunk        auto   auto 1000BaseSX SFP
Gi1/0/8                      notconnect   1            auto   auto Not Present
Gi1/0/9                      notconnect   1            auto   auto Not Present
Gi1/0/10                     notconnect   1            auto   auto Not Present
Gi1/0/11                     notconnect   1            auto   auto Not Present
Gi1/0/12                     notconnect   1            auto   auto Not Present
Fa3/0/1            disabled     753          auto   auto 10/100BaseTX
Fa3/0/2              Connect notconnect   753          auto   auto 10/100BaseTX
Fa3/0/3                   Connect notconnect   753          auto   auto 10/100BaseTX
Fa3/0/4                      disabled     753          auto   auto 10/100BaseTX
Fa3/0/5                      disabled     753          auto   auto 10/100BaseTX
Fa3/0/6                      disabled     753          auto   auto 10/100BaseTX
Fa3/0/7                      disabled     753          auto   auto 10/100BaseTX
Fa3/0/8                      disabled     753          auto   auto 10/100BaseTX
Fa3/0/9                      notconnect   811          auto   auto 10/100BaseTX
Fa3/0/10                     disabled     753          auto   auto 10/100BaseTX
Fa3/0/11                     disabled     753          auto   auto 10/100BaseTX
Fa3/0/12                     disabled     753          auto   auto 10/100BaseTX
Fa3/0/13                     notconnect   753          auto   auto 10/100BaseTX
Fa3/0/14                     disabled     753          auto   auto 10/100BaseTX
Fa3/0/15                     disabled     753          auto   auto 10/100BaseTX
Fa3/0/16                     disabled     753          auto   auto 10/100BaseTX
Fa3/0/17  Connection for Key connected    753        a-half  a-100 10/100BaseTX
Fa3/0/18  Connection for Key notconnect   753          auto   auto 10/100BaseTX
Fa3/0/19   notconnect   753          auto   auto 10/100BaseTX
Fa3/0/20                       notconnect   753          auto   auto 10/100BaseTX
Fa3/0/21                       connected    753        a-full  a-100 10/100BaseTX
Fa3/0/22                  notconnect   753          auto   auto 10/100BaseTX
Fa3/0/23                      notconnect   753          auto   auto 10/100BaseTX
Fa3/0/24                 connected    753        a-full  a-100 10/100BaseTX
Gi3/0/1                      notconnect   1            auto   auto Not Present
Gi3/0/2                      notconnect   1            auto   auto Not Present
MRM-Admin-SW01#
That's because your switch 1 ( ex switch 2) has a flat config.
Before renumber an active switch you have to:
- copy running config of actual switch you want renumber
- paste the config on a notepad
- modify the pasted config renumbering ports with ghe new switch number (eg.
interface Ge 2/0/1
switchport access vlan 100
will become
interface Ge 1/0/1
etc)
copy the modified config from the notepad and paste it to switch terminal session in configuration mode.
That's all.
In this way you should have the switch 1 with the exact same configutation of ex switch 2
Carlo
Please rate all helpful posts "The more you help the more you learn"
7 Replies 7
Hi.
In your configuration didn't exist switch 1 and related configuration for this "modue"
So this behaviour is normal.
when you renumber a switch it doesn't take it's actual config with him.
If you want the same configuration you have first to provision the switch in desired stack position and copy the config of the switch you want renumber and applying to the new module renumbering ports.
Carlo
Ok so what should I do to fix this?  I want this to be consistant and I want what was switch 2 (now switch 1), to have it's configuration under switch 1 of the running config.
Hi.
As I mentionetd you have to take switch 2 interface config and edit all port configuration with 1 (eg 2/0/1 to 1/0/1)
regards
Carlo
Ok I can do that but how is my switch running properly?  If I look at my running config, my port 2/0/2 was a trunk with a description, etc. But if I look at the running config of 1/0/2 it doesn't have any of that.  I really don't get how it's working if I have to enter the configuration again.  How are my other switches connected to this..still working if I have to enter the commands again on a port?
The sh int status has the right info, that it's trunked but didn't carry over the descriptions etc.  Sorry, I just don't get this at all.  I don't know how they can have them being different.
Port 1/0/1-12 have no configuration on them, but somehow they are showing trunked, etc.  So my switchport that was 2/0/1 was on vlan225, now g1/0/1 is showing vlan1, so theoretically that device is connected but on the wrong vlan?  How are the trunks still up since they have no trunk configuration on the ports?
interface Ge 2/0/1
will become
interface Ge 1/0/1
etc)
That's all.
Carlo
Leo Laohoo
1.  In switch 2, enter the command "switch 2 renumber 1".
2.  Don't reboot.  Enter the next stuff:  switch 1 provision ws-c3750g-12s
3.  Copy the interface configs of switch 2, edit it to change it all to switch 1.
NOTE:  If you want to renumber switch 3 to 2, do "switch 3 renumber 1" and POWER DOWN this switch.
4.  Save the config;
5.  Make sure you HAVE NOT POWERED UP the new switch;
6.  Reboot the switch 2.
Steps 1 and 2 are already done, that is what I did originnally.  I just thought it would take the config with it.  The thing that confused me what things were still working (trunk wise) on switch one, with no configuration, no trunk commands.  The other switches stayed up.  So I'm thankful for that.
I think I'm going to renumber switch 1, back to switch 2..it already has the config in place, then the new switch will be switch 1 and I will enter the new configuration for it..and mount it on top..probably make the master once it joins the stack.
