Community Member
What does ignored counters on vlan1 signify?
Hi Netpro Community,
I have a question:
When I run show int on vlan 1, I notice a high number of ignored. What does this means?
Vlan1 is up, line protocol is up
Hardware is CPU Interface, address is 0015.f90c.1140 (bia 0015.f90c.1140)
Internet address is 137.55.136.12/23
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Last input 00:00:00, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 20000 bits/sec, 31 packets/sec
5 minute output rate 4000 bits/sec, 6 packets/sec
153100183 packets input, 3082454627 bytes, 0 no buffer
Received 107721373 broadcasts (0 IP multicast)
0 runts, 0 giants, 2256 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 13953022 ignored
19109087 packets output, 2016292687 bytes, 0 underruns
0 output errors, 2 interface resets
Switch Version and Information:
XXXXXXXXXXXXXX uptime is 8 weeks, 2 days, 18 hours, 23 minutes
System restarted at 15:52:28 SG Sun May 11 2008
System image file is "flash:/c2950-i6q4l2-mz.121-22.EA4a.bin"
cisco WS-C2950-24 (RC32300) processor (revision R0) with 21039K bytes of memory
Processor board ID FOC0941Z76W
Last reset from system-reset
Running Standard Image
24 FastEthernet/IEEE 802.3 interface(s)
Public buffer pools:
Small buffers, 104 bytes (total 31, permanent 25, peak 115 @ 7w0d):
30 in free list (20 min, 60 max allowed)
64207216 hits, 3042 misses, 5208 trims, 5214 created
0 failures (0 no memory)
Middle buffers, 600 bytes (total 15, permanent 15, peak 39 @ 7w0d):
14 in free list (10 min, 30 max allowed)
3712487 hits, 325 misses, 133 trims, 133 created
10 failures (0 no memory)
Big buffers, 1524 bytes (total 6, permanent 5, peak 22 @ 5w5d):
6 in free list (5 min, 10 max allowed)
573627 hits, 1733 misses, 1208 trims, 1209 created
1316 failures (0 no memory)
VeryBig buffers, 4520 bytes (total 10, permanent 0, peak 14 @ 4d10h):
10 in free list (0 min, 10 max allowed)
124107 hits, 578 misses, 68 trims, 78 created
573 failures (0 no memory)
Large buffers, 5024 bytes (total 1, permanent 0, peak 6 @ 5w6d):
1 in free list (0 min, 5 max allowed)
263 hits, 310 misses, 552 trims, 553 created
310 failures (0 no memory)
Huge buffers, 18024 bytes (total 1, permanent 0, peak 3 @ 5w6d):
1 in free list (0 min, 2 max allowed)
103 hits, 207 misses, 545 trims, 546 created
207 failures (0 no memory)
Interface buffer pools:
Calhoun Packet Receive Pool buffers, 1560 bytes (total 256, permanent 256):
223 in free list (0 min, 256 max allowed)
154038050 hits, 0 misses
Any explanation would be appreciated.
Rgrds,
Benson
1 REPLY
Community Member
Re: What does ignored counters on vlan1 signify?
Hi Benson,
Check this url:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bfd6.shtml#shwop
From the output you've provided I would say it's being caused by broadcasts
340
