Hi Alphonse
I suspect the "MinFail" status comes from:
%C6KENV-SP-4-MINORTEMPALARM: module 1 inlet temperature crossed threshold #1(=50C). It has exceeded normal operating temperature range.
%C6KENV-SP-4-MINORTEMPALARM: EARL 2/0 inlet temperature crossed threshold #1(=53C). It has exceeded normal operating temperature range.
So it seems a temperature problem. Cisco recommends:
Verify that air flow to the device is not blocked and that the fan is operational.
