Community Member
what does this BGP AS expression stands for?^(4837_)+9800
please help me
1 ACCEPTED SOLUTION
Re: what does this BGP AS expression stands for?^(4837_)+9800
Hi, wlsi
No, the parenthese pair showed up on your question are matacharacters. They have special meaning and will not match the parenthese showed up on the AS-PATH attribute. To match a BGP confederation route which has perenthesis pair in the AS-path attribute, use \( and \) instead. This "\" prior to the "(" and ")" will cancel the special meaning of "(" and ")", and just match the character "(" and ")".
For example, if you want to match the following AS-PATH exactly
(65000)
use the following regular expression
^\(65000\)$
SSLIN
This means an AS-PATH coming from AS 4837, and having AS 4837 at least once and then AS 9800.
HTH,
Mohammed Mahmoud.
Hi, wlsi
It match those routes with AS-path atrribute which is beginning with one or more 4837s (this means those routes come from AS 4837 and these routes have or have not been manupulated by AS pre-pending), followed by one 9800(this means AS 4837 accepts these routes from AS 9800), then followed by anything (and this means these routes might or might not be originated from AS 9800).
SSLIN
Community Member
is it possible for a BGP confederation route ?it is also with a pair of ()
Hi, wlsi
(65000)
^\(65000\)$
SSLIN
194
