What is native IOS
chirag-pandya
Hello All,
Ihave some doubt about IOS.
PLease help me for understanding how many type of IOS like Native then CAT IOS.
Thanking You,
Chirag Pandya
2 Accepted Solutions
ankbhasi
Hi Chirag,
There are only 2 kinds of mode which CAT6500 support.
HYBRID MODE & NATIVE MODE
In Hybrid mode you have 2 images one is CATOS on sup and IOS on MSFC and you need to configure switch on CATOS and MSFC on IOS.
In Native IOS mode there is a single image for sup and msfc residing on sup engine and with single interface you have to configure msfc as well as switch.
Check this link for more details
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008010e9d5.shtml#Diff
Ankur
*Pls rate all helpfull post
smothuku
Level 7
Level 7
Hi Chirag ,
The combination of CatOS on the Supervisor Engine and Cisco IOS Software on the MSFC is
referred to as the "hybrid" OS. The hybrid model operates as you know based on two
operating images, two configurations, and two command lines; one for each CatOS and Cisco
IOS Software.
Cisco IOS Software for he Supervisor Engine on the Catalyst 6500 Series (also known as
"Native" model) provides a single Cisco IOS image, configuration, and command line to
support all Layer 2, 3, and 4 functionality on the switch. Cisco IOS has historically been
a Layer 3 operating system on routing platforms, and when installed on the Supervisor Engine of a Catalyst 6500 has expanded these capabilities to include true Layer 2 functionality as well.
If you're thinking about a conversion from Cisco IOS to CatOS we must to be sure new
Hybrid OS be capable to support all modules/features you've or you'd like to obtain.
check the below links.
http://www.cisco.com/en/US/customer/products/hw/switches/ps708/products_white_paper09186a00800c8441.shtml
http://www.cisco.com/en/US/customer/products/hw/switches/ps700/products_tech_note09186a00801350b8.shtml
Hope it helps you..plz rate it.
satish
mahmoodmkl
Level 7
Level 7
native IOS means the ios which is developed by cisco for its devices.
catos i think it was incorporated from catalyst company.it is solely for layer 2 operations.
hybrid this is for catos on u r sup and ios on u r MSFC.
Mahmood
ankbhasi
Hi Chirag,
Ankur
smothuku
Level 7
Level 7
Hi Chirag ,
IOS Software.
satish
