What is the input rate limit/max on a vlan interface?
mckneely1
  Vlan1, as shown in the output below, is getting close to 1 Gbps and i'm worried that it will start to drop packets.  I know that physical interfaces have a speed limit of 100 or 10000 but what is the limit of a virtual interface (vlan1)?
6509E_1#sh int vlan1
Vlan1 is up, line protocol is up
  Hardware is EtherSVI, address is 001e.498f.3800 (bia 001e.498f.3800)
  Internet address is 10.30.0.10/16
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 27/255, rxload 143/255
  Keepalive not supported
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 29w0d
  Input queue: 0/75/319965/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 920757000 bits/sec, 100733 packets/sec
  5 minute output rate 109690000 bits/sec, 69695 packets/sec
  L2 Switched: ucast: 38127819259 pkt, 34815805864441 bytes - mcast: 211929687 pkt, 24160555629 bytes
  L3 in Switched: ucast: 284774661762 pkt, 288770895469933 bytes - mcast: 0 pkt, 0 bytes mcast
  L3 out Switched: ucast: 207676756187 pkt, 55103932658430 bytes mcast: 0 pkt, 0 bytes
     284980720796 packets input, 288794501667563 bytes, 0 no buffer
     Received 183946216 broadcasts (8820452 IP multicasts)
     0 runts, 0 giants, 2552 throttles
     207770123124 packets output, 55118868952804 bytes, 0 underruns
     0 output errors, 0 interface resets
Jose Solano
Level 4
Level 4
You can infer that the SVI rate is 1gig by looking to the bandwidth and delay vales, normally for 1gig interfaces you will see this:
#sh int gi 1/11 | i DLY
And according to your output the SVI has the same bandwidth and delay that a physical 1gig port which are the default values assing to the physical ports.
Hope this helps.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
There shouldn't be any (by default) bandwidth limit on a VLAN interface.
A VLAN interface's in and out bandwidth would be the aggregate of all the interfaces (on same device) that are part of the VLAN.
