09-10-2010 05:49 AM - edited 03-06-2019 12:54 PM
Hi All
What is the maximum speed of trunk/stack can be configured in WS-C3750G-24T-Switch?
Siva
Solved! Go to Solution.
09-11-2010 05:01 AM
No. As already mentioned above to have 10g interface, you gonna have to upgrade to 3750-E or 3750 or 3560 X series. They support 10GbE SFP+ Ports.
On 3750g, you proberbly can have max 8g by aggregating 8 ports in a port-channel.
Francisco.
09-10-2010 07:00 AM
The maximum speed supported by each Stack cable is 16 Gbps. Since you will
have two paths in the stack, the effective speed will be 32 Gbps. Trunking
speed depends upon the type of link you are using. If you are using Gig
Links, it will be a max of 1 Gig (if you go for Etherchannel with multiple
Gig links, then it will be sum of the total bandwidth of all gig links).
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/prod_white
_paper09186a00801b096a.html
Hope this helps.
NT
09-10-2010 07:27 AM
Thanks NT
Can u please tell me what is the maximum trunk speed an configure in this switch?
will it support 10 Gb trunk?
09-10-2010 08:49 AM
The 3750-E versions have the 10GB ports. http://www.cisco.com/en/US/products/ps7077/
Regarding the stacking speed just to add to above comments, when two or more switches are connected via stackwise cable, a switch fabric consisting of dual counter-rotating rings if formed, with each ring providing 16Gbps of bandwidth, resulting in 32Gbps of total bandwidth.
Francisco.
09-10-2010 09:01 AM
Just to add to that the StackWise Plus and StackWise can support up to 2 Ten Gigabit Ethernet ports per Cisco Catalyst 3750-E
Francisco.
09-10-2010 08:58 AM
3750E and 3750X switches support 10G links. Regular 3750 does not support
10G modules. So, if you have 10G module, then yes, you can have a trunk of
10G bandwidth.
NT
09-11-2010 03:08 AM
so you mean to say i can add 10g module
in this switch(3750g)
Thank you very much.
09-11-2010 05:01 AM
Francisco.
