Community Member
What is the technical difference among:Ethertnet,Fastet and GigEthernet?
Folks, I understand that Ethernet (10Mbps) FastEthernet (100Mbps) and GigEthernet (1Gbps) have same frame (IEEE 802.3) and operate with CSMA/CD.
Then on the GigEthernet, I understand that the CMSA/CD scheme was enhanced with carrier extension and frame bursting.
Is the information above correct or I am missing something to explain how the Fast and Gigbitethernet can deliver higher speeds?
Silver
Re: What is the technical difference among:Ethertnet,Fastet and
In my opinion you get higher speed becuase of better technology available to make Transmitter/Receiver operating at those higher speed, modulation techniques etc.
CSMA/CD is basically reducing your speed when same media is shared by several users whereas most of the network is switched where CSMA/CD is not used.
Enhanced carrier extension and frame bursting for Gig etherent is method to use CSMA/CD for higher speed.
Purple
Gigabit speeds are achieved by running data across all 8 wires as opposed to just using wires 1,2,3 and 6 . You must have 4 good pairs of wires within the data path otherwise it wilkl only negotiate 100 meg or lower. For a real technical answer just google it .
108
