Community Member
What's difference between WS-C2960S-48TS-L and WS-C2960S-48TS-S
"What's the big difference between WS-C2960S-48TS-L and WS-C2960S-48TS-S? What' the meaning of the -L and -S? "
In Cisco 2960 series switches,-L means LAN Base while -S means LAN Lite.To compare those two cisco 2960 switch, you can follow:
WS-C2960S-48TS-L is a Catalyst 2960S 48 GigE 4 x SFP LAN Base Switch ,which is an easy-to-use Layer 2 edge switch suits for enterprise, midmarket, and branch office networks with highly secure business operations, improved sustainability, borderless network experience and lower total cost of ownership.
WS-C2960S-48TS-S is a Catalyst 2960S 48 GigE 2 x SFP LAN Lite Switch ,which simplified from Lan Base software to Lan Lite for more adaptation if customers’ business is entry-level branch office or wiring closet networks, distinguish with Lan Base software for a more complex business requiring.
Everyone's tags (1)
Hall of Fame Super Blue
"-L" means the switch is
"-L" means the switch is loaded with LAN Base IOS.  "-S" means the switch is loaded with a cut-down, watered-down of the LAN Base IOS called LAN Lite.
Go HERE and the difference between the two starts from page 5.
Hey Bejiening,You can check
Hey Bejiening,
You can check out more information regarding the different model switches by following this link below.
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-s-series-switches/data_sheet_c78-726680.html
585
