08-27-2014 01:27 PM - edited 03-07-2019 08:33 PM
What switches, if any, support Netflow?
08-27-2014 05:53 PM
1. Flexible NetFlow for High-end chassis switches such as 4500, 6500 switches
2. Netflow for L3 switches (same config as the router but additional MLS configs)
Terms:
MLS -Multi-Layer Switching
Don't forget to rate or mark as correct helpful post! :)
08-28-2014 03:57 AM
Almost all Cisco devices support NetFlow since its introduction in the 11.1 train of Cisco IOS Software and because of this, NetFlow is most likely available in any devices in the network. For the more details on the netflow deployment and which Cisco platform support it refer the below link ( refer table 1).
Sandeep
08-28-2014 04:02 AM
in addition you can refer this link too
http://www.manageengine.com/products/netflow/help/cisco-netflow/netflow-ios-versions.html
