Webcast-Catalyst9k
Where's the Port Security
Howdy
I set up port security on 5 ports in packet tracer. See attach.
1) Why does sh port-security show nothing?
2) Why does it show Disabled?
3) Also if it is Disabled why does it show Secure-down. Doesn't that only happen with a violation.
I did shutdown the interface and did a no shut with no effect. Still no port security
I set it up on a single port without interface range and it still shows down.
Any experts out there on this. thanks a bunch.
int range fa0/1-5
switchport  port-security  violation  shutdown
switchport  port-security  mac-address  sticky
1 ACCEPTED SOLUTION
Re: Where's the Port Security
I don't have the Packet Tracer handy right now but if the indicated configuration is complete then I believe you are missing the command
on the ports. This command actually activates the port security with the settings (sticky learning, shutdown violation reaction) you have already configured. Omitting this command is actually one of the most common errors when configuring port security.
Best regards,
Peter
Best regards,
Peter
You are absolutely right. That did it. Don't know how I missed it in the Sybex book or Odoms.
In fact I don't think Odom shows it. I like Odom's book a lot but its a bit deficient in the configuring area.
Odom said "Secure-Down" means a violation shut down the port.
I guess it also means port security has not been enabled.
thx
232
