Where to apply QOS ?
Hi, After defining the policy maps , how does one decide where and in which direction should the policy be applied ?
2 Accepted Solutions
Outbound on the Spoke serial interface would guarantee 20kbps of traffic to Hub. To guarantee the return traffic you should apply it outbound at the HUB to each spoke site as well.
Jon
Yes.
Outbound on your CPE router, and make sure that the service provider does the same on their PE router.
Actually you can do classification input on your Eth inteface.
BR,
Bjornarsb
6 Replies 6
kerek
Level 4
Level 4
You can bound the policy-map to the interface under the interface config mode using service-policy input/output
Hope it helps,
Krisztian
Hi Kerek,
Thanks for the reply, but my question is how to decide whether to apply the policy inbound or outbound on a interface.
If you take a Hub and Spoke environment with each spoke connected to the HUB using a 64 kbps leased line, and i want guarantee an bw of 20kbps for http traffic per branch , where should i applcy the policy ???
class-map match-any HTTP
match protocol http
policy-map HTTP
class HTTP
bandwidth 20
where should i apply this policy ???
HUB Serial inbound or outbound
SPOKE Serial inbound or outbound
I hope you got my question..
Jon
Hi Jon,
So I need to apply the policy both on Spoke Serial and Hub Serial in Outbound directions, Is that what you meant ?
-vikram
Yes.
BR,
Bjornarsb
thanks for the reply, It answered my question - vikram
