Which command is able to display interfaces' IP address, status and uptime?
Thanks for help.
1 ACCEPTED SOLUTION
Bronze
Re: Which command is able to display interfaces' IP address, sta
The command: show ip interface brief will show the interface name, it's IP address, when the IP was set (boot time, or by config) it's current physical and logical status.
And I don't know about uptime, but the command: show interfaces link will show how long a physical interface has been down.
Bronze
Thanks for help
router#show logging
Will show you a history of all interfaces and the UP DOWN status.
you might want to increase the log size to get more keep more information
router#logging buffered 4096 errors
Blue
John:
You may want to reconsider your advice.
Executing a "sh log" will not give you any interface status and configuration information at all.
Yes, if an interface happened to go down or come back up, there will be an indication in the log. But that is hardly a reasonable way to go about getting interface information.
Victor
Silver
take a look at:
show interfaces status
looks quite useful imo.
hth,
Ajaz
215
