Which IOS image to choose for 7206VXR/NPE-G2
dan_track
I've just logged on to the cisco site to download an image for my new router it's a 7206VXR/NPE-G2 (never used this before). On teh Cisco download page I'm offered multiple choices:
Channel Port Adapter (CPA) Microcode
IOS Boot Images
IOS Field Programmable Devices
IOS Software
Protocol Description Language Module (PDLM) Software
My question is what exactly do I need to download and what is the difference between each especially between "IOS Boot Images" and "IOS Software".
Dan
9 Replies 9
You have to go to IOS images, there you can download the respective IOS for your router.Based on your requirement you can download the respective IOS from cisco portal..
IOS boot image already will be there in your router,this will help to load the necessary IOS on your router.
If you have multiple IOS images in your flash , then you need to set the boot sequence in boot image, that wull help the router which IOS should load ,and if that fails then it has to load from second IOS.
IOS is the main image where we can do all the networking futures . Boot image is the file that will help the router to know , from which IOS it has to come up.
Karuppu
Giuseppe Larosa
Hello Dan,
boot images are boot loaders :
the system starts by loading rommon, that then load the boot image that is subset of IOS
The boot image then loads the full IOS image
about both boot images and full IOS images be aware that there are images specific for this type of processors NPE-G1 and NPE-G2
An example of full IOS image is :
c7200p-advsecurityk9-mz.124-20.T.bin
sh ver | inc image
System image file is "disk2:c7200p-advsecurityk9-mz.124-20.T.bin"
images starting with C7200p* are the right ones
sh ver | inc NPE
Cisco 7206VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memory.
Edit:
not recommended but sh ver shows
sh ver
Cisco IOS Software, 7200 Software (C7200P-ADVSECURITYK9-M), Version 12.4(20)T, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 11-Jul-08 05:00 by prod_rel_team
ROM: System Bootstrap, Version 12.4(4r)XD5, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200P-KBOOT-M), Version 12.4(15)T6, RELEASE SOFTWARE (fc2)
the boot loader is the boot image that in this case is a little older then main IOS image.
Usually Cisco recommends to have the same.
Hope to help
Giuseppe
Hi.
Thanks for that. What about the other sections what are they for? Do I need to be concerned by them?
Dan
No need to consider about other things..
Karuppu
What's the best way to update both the ios and boot loader. Can someone tell me the commands.
Dan
Hi Dan,
Follow this document on how to upgrade your router.  Make sure you have enough memory (256MB) and flash (128Mb) installed in your router if you are upgradeing to IOS 15.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a00801fc986.shtml
Reza
Thanks for that.
I tried booting  but I got the following error:
Error : compressed image checksum is incorrect 0x3587170F
        Expected a checksum of 0xA17ACCD2
*** System received a Software forced crash ***
signal= 0x17, code= 0x5, context= 0x0
System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
Socket jumper: not present Failsafe jumper: present = normal
FPGA revision 0x00000026
C7200 platform with 1046528 Kbytes of main memory
Readonly ROMMON initialized
string is disk2:c7200p-adventerprisek9-mz.124-24.T2.bin
And I can see:
BOOT variable = c7200p-adventerprisek9-mz.124-24.T2.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable = bootflash:c7200p-kboot-mz.124-24.T2.bin
WARM_REBOOT variable = FALSE
How can I verify a checksum after I upload it via tftp?
Dan
With the following:
sh bootvar
Why is the BOOTLDR and BOOT variables different?
The BOOTLDR is the correct one so how do I change the BOOT variable?
Dan
Dan,
Ok so if the  BOOTLDR is the correct, then at the prompt type this command:
boot bootflash:c7200p-kboot-mz.124-24.T2.bin
and see if it boots correctly
Reza
