Which is prioritized for multicast traffic if FastSwitching and CEF is enable?
                   Hello
Here is the related configuration and output of show command below,
In my understanding, there are 3 swtching mode, CPU, fast-swthing and CEF swthing,
But if FastSwthing and CEF swithing are enable both, then which swithing mode is prioritized for mutlicast traffic?
interface Vlan302
ip address 10.0.20.1 255.255.255.0
3750X#sh ip int vlan 302
Vlan302 is down, line protocol is down
  Internet address is 10.0.20.1/24
  Broadcast address is 255.255.255.255
  *omit
  IP fast switching is enabled
  IP Flow switching is disabled
  IP CEF switching is enabled
  IP CEF switching turbo vector
  IP Null turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is enabled
  IP route-cache flags are Fast, CEF
  *omit
interface Vlan301
ip address 10.0.10.1 255.255.255.0
no ip mroute-cache
3750X#sh ip int vlan 301
Vlan301 is down, line protocol is down
  Internet address is 10.0.10.1/24
  *omit
  IP multicast fast switching is disabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, CEF, No Distributed
  *omit
Product : Cat3750X
IOS version :  15.0(2)SE5
Best Regards,
Masanobu Hiyoshi
Super Bronze
Re: Which is prioritized for multicast traffic if FastSwitching
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I'm not 100% certain, but I believe FastSwitching and CEF switching apply to unicast, not multicast.  Your "IP mroute-cache" command enables/disables fast multicast switching.
On a 3750, switching should be hardware based, for unicast and multicast, unless TCAM resources are insufficient.  If hardware switching falls back to non-hardware switching, you'll likely find process vs. Fast vs. CEF vs. multicast doesn't matter, all too slow.
Hello
Thank you very much for this precious information.
I think if catalyst switch treats mulcast packet as fast-switching by using mroute-cache command.
if it is not using, CPU processing would be using them.
If it is correct, then performance is slightly difference between the multicast fast switching and CPU processing right?
Thank you and best regards,
Masanobu Hiyoshi
412
